I recently bought a G.SKILL Phoenix Pro Series FM-25S2S-120GBP2 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD) from Newegg.
My MacBook Pro mid-2010 does not recognize the drive when I plug it in and try to install Mac OS X on it. Disk utility only sees my DVD drive. I tried plugging the SSD drive in my PC's SATA port and flash the firmware. It seemed to work, but the drive already had 3.1
installed so the actual installation failed. I don't know what I should do next, should I RMA it? I've spent about 10 hours trying to troubleshoot the problem last night and today.
I tried plugging it into a USB external case and formatting it inside another computer with OS X and everything is fine. The drive exists and works great as an external drive.
Can you help me find a solution before I return it? This is getting really tough to figure out.
Thanks for your help.
