Slower than any other ssd in this forum (pheonix pro 240GB)
  • Slower than any other ssd in this forum (pheonix pro 240GB)
    Hi All.
    My crystaldiskmark shows that my ssd is WAY slower than any other ssd in this forum. Any help would be very very appreciated.
    I use
    Phoenix Pro 240GB (decided to buy this expensive one instead of buying a new laptop!!)
    Windows 7 32-bit
    Intel Mobile Core 2 Duo T7200 @ 2.00GHz Merom 65nm Technology <-- pretty old?
    4GB RAM
    I followed the tweaks such as BIOS update, partitions, and Intel Rapid Storage Tech.
    I also tried to securely erase my ssd using Gparted, but it keeps saying "permission denied." I have tried to change my user profile to the master/root user by "su" or "su -l root" but Gparted asked me to keyin password, which I never set up --> "authentication failed" message followed immediately.
    Somewhere in the forum, some users suggested using "clean all" command in diskpart, so I tried that, but no performace gain as shown in the picture above. The procedure was: backed up the entire image using acronis --> "clean all" using diskpart (windows 7 DVD booting) --> restored backup image --> waited for around 30 minutes --> crystaldiskmark
    So, please help me! Thank you so much!
    Hi rangernoh
    I know you are disappointed with this performance.
    I have already know that.
    please give me more time, I will provide you a perfect solution.
    thanks
      I would really appreciate it if you could provide a perfect solution!
