Issue with 2x 60gb Phoenix Pros
  • Issue with 2x 60gb Phoenix Pros
    I just put two 60gb Phoenix Pros in RAID 0 but they're not detected when I try to apply the firmware 2.1 update. I'm using "AMD AHCI Compatible RAID Controller" V3.1.1540.127
    Hi JayLayne3
    after upgrade firmware, you should rebuild RAID mode.
    because it can't recognize.
    do you mean you can't set RAID 0 or.....?
      I have configured raid. The firmware just can't detect the drives.
      What do you mean by upgrade and then rebuild?
        Hi Jay
        It is right because the tool only recognize sandforce drive.
        when you build RAID 0, it show the motherboard's chip drive.
        so this tool can't work.
        could you backup your data first
        then upgrade ssd individually and rebuild raid 0 again
