Hello! I'm new here and I've a question about my new Phoenix Pro 120GB (firmware 2.1): I've tested it with a lot of benchmarking software and I've found the same results: performances are always lower than gskill reference (http://www.gskill.com/products.php?index=284)
For example with ATTO 2.46:
Gskill reference:
4.0KB Read = 136606 byte/sec
4.0KB write = 191084 byte/sec
My results:
4.0KB Read = 67962 byte/sec
4.0KB write = 92638 byte/sec
I've:
I can't enable AHCI because my sony vaio NB hasn't this bios option, but I'm pretty sure AHCI is always enabled because windows automatically installs AHCI drivers and the value of "Start" into the key "HKEY_LOCAL_MACHINE/System/CurrentControlSet/Services/Msahci" is 0.
My question is: what else can I check to obtain the best results? The SSD speed also depends on notebook hardware?
I've also tried to switch to microsoft AHCI drivers but the performances are about the same.
Gskill reference:
My results:
I've:
- installed a new copy of windows 7
- installed intel rapid storage Ver:9.6.0.1014
- verified trim enabled
- verified alignment
- disabled all windows services that continuosly write to HD
- installed ssd tweaker 1.6.1 and unchecked every selection box
