I'm running a 60 GB Phoinex Pro connected to a MSI P45-motherboard. I have AHCI enabled (and Intel Rapid Storage-driver installed).
I have tried to format the drive using hdparm. Should this operation just take a second? The feedback I get is the same as G.Skills guide. Performance seemed to went up a bit after this, but with some more (quite heavy) use, it goes down...
I have updated the firmware.
When looking at the benchmarks from G.Skill and some others I'm not close to the performance.
In AS SSD I get 95MB/sec in seq. write perfomance. Also in Crystal Diskmark the performance is on the same level. But after some more use the write-speed goes down now to 60-65 MB/sec.
I also have a Crucial C300. With the same use on the same system, I havn't so far seen any decrease in performance.
From what I understood, SF-1200 SSD's should support both Trim and have a internal "garbage collection", so that the performance should stay good....
