Help for install firmware falcon 2030
  • Help for install firmware falcon 2030
    I need some help please.
    How can I make a bootable usb stick for update the firmware of my falcon ? I am on windows 7 x64.
    Now my key's working, i see all Falcon files but i have a problem :
    I move my ssd to the IDE mode, I see my ssd (falcon 1, 128gb, firmware 1571) (1)
    when i write 1 and i valid, i have this message :
    [ERROR] DMA Invalid device
    [ERROR] Firmware customer type read fail
    Ivalid SSD
    I don't use jumper. Same problem with : - 128gb-1, 128gb-2 and 128gb-3 files
    Do you have a solution ?
      I reinstall the 1916 firmware, I disconnect all cd dvd drives, after I reboot with my usb stick and install the 2030 firmware without problem
      I think we have to update to 1916 firmware before install the 2030 firmware
        Hi ffm76600,
        Thanks for your information, i'll add it to the note.
