I just bought 2x 60 GB Phoenix Pro drives for a RAID 0. The performance was definitely faster than mechanical drives but much slower than I was expecting. After reading about the lack of trim support in RAID, I started thinking this might be the problem. So, I disabled the RAID and reinstalled Windows 7 Home Premium on a single 60 GB Phoenix Pro SSD. The benchmark performance was still slower than advertised but much faster, about 2x, than the RAID 0. I'm not sure if I have my system configured incorrectly or what.
I have a Intel i7 2.8GHz, Gigabyte GA-X58A-UD3R, 6GB RAM, 2x Phoenix Pro SSD 60GB, 2x Nvidia GTX 470 SLI. I plugged the SSDs into the Marvell SATA III ports at 6GB/s as it supports RAID 0. I plan to use the Intel SATA ports for a RAID 5 storage using mechanical drives. I don't have the mechanical drives installed so this is definitely not the problem. I also have ACHI enabled on the Marvell ports.
I'm not sure if I should try to re-configure the RAID or run the single SSD. I'm surprised how slow the RAID 0 was!
My other concern is how do I maintain the speed of the RAID without trim support? Does the drives support Garbage Collection? I heard that even on RAID Garbage Collection works. The other option I saw is to use the following maintenance guide - http://www.ocztechnologyforum.com/fo...-not-need-this
What could be wrong with the performance of the SSD / motherboard? Do I need to disable features of Windows 7 such as Superfetch since Windows 7 doesn't see the RAID as SSD drives? If I need to disable some features, could you please point me to what I need to disable?
David
David
