Thanks to anybody that can clear things up for me.
I did a fresh install on a Phoenix Pro FM-25S2S-120GBP2 last night using Win7Pro64.
-AHCI was NOT enabled in the bios for the install
-Windows did NOT recognize the drive as SSD and had it scheduled to defrag
-After installation and further reading I enabled AHCI in the bios and used the auto function of SSD Tweaker (program located on the OCZ forum that I found linked to in this form)
see performance pictures below. I'm aware that running crystal disk is bad so I just did sequential
My questions are:
1. this is low performance right?
2. how bad was it that AHCI was not enabled when I installed?
3. what should I do?
4. is there a post that has a simple set of instructions. I don't want to be a power user... just want to get it installed correctly. I don't know how to format this drive.... align .....so I'm a little lost and all the post leave me scratching my head because they look like a bunch of random tweaks that overlap.
Thank you very much.
My questions are:
