I am about to set up 2 x 64GB Falcon II in a RAID 0 array. The array will hold the OS and programmes. I have 3 alternatives to place the data (need the data on a D drive). I can a) partition the array to include the D drive, b) install a 3rd SSD (Falcon 128GB) to hold the data, or to use a platter drive (7200rpm) to hold the data.
What do you recommend to get the best stability and performance?
