Is it of any signifance to have 2 similar SSDs in a RAID 0 configuration? Or, is it OK to have 1 Falcon II 64GB and 1 Falcon 128GB in a RAID 0?
Required to have same SSDs in RAID 0?
Preferably you want to have the same types of drives in your Raid, but long as they are the same size it will work and the difference between the Falcon I vs. Falcon II should be very minimal if not any.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
RAM 12Gb Patriot Viper Xtreme Division-2 DDR3 @ 1908Mhz
PSU Corsair AX 850W
SSD: Intel X25M 80Gb
HD 2x WD VelociRaptors 150Gb in Raid-0
Sager NP8662
CPU: Intel Q9100 @ 2.38 GHz
GPU: GTX 260M @ 612Mhz
RAM: G.Skill DDR3 1066Mhz 4Gb
SSD: Intel X25M 120Gb
