F5-6000J3038F16GX2-FX5 will this be compatible with this mobo
B650m pg riptide
There are two way to find out about compatibility yourself. You either check the QVL of the memory
https://www.gskill.com/qvl/165/396/1...F16GX2-FX5-QVL
or can take a look at the configurator for your motherboard
https://www.gskill.com/configurator?...del=1665623982
to get a full list of all compatible models.
Just remember that the stated compatibility is valid for single kit use & dual channel motherboards support most SKUs only with two modules in their primary DIMM slots.
- 1 like
