Hi All,
I have 2x32GBs of F5-6000J3040G32GX2-TZ5RK installed in my PC (XMP enabled) and I have noticed that they can get quite hot:
Stress tests:
TestMem 5 / OCCT RAM test: 64c after 15 minutes.
Gaming: 48c-50c during gaming.
The above is based on HWInfo SPD Hub Temperature, which apparently is not even the hot spot. I have a Lian Li O11 Dynamic Evo XL case with 3x140mm bottom, 3x140mm side, 3x120mm top and 120mm rear fans so airflow is more than adequate.
Are these temps OK? TM5 and OTCC did not start throwing errors even after hitting 60c but then again I only ran those for about 15 minutes. Would be good to understand if it's just me experiencing such high temperatures with this kit or others have a similar experience.
Turning RGB off dooes not significantly improve temps.
Your help is greatly appreciated.
Stress tests:
