Hello, I'm buying a new CPU and motherboard, specifically a Ryzen 7 7800X3D to be mounted on a Gigabyte X670 AORUS ELITE AXboard.
The board RAM compatibility list include these RAM modules: F5-6400J3239G32GX2-TZ5RK, while in a store I found an offer for those ones: F5-6400J3239G16GX2-TZ5NR. They look to be the same thing, even if the P/N code differs by the last two characters.
Do you know if there is any actual technical difference between the two?
Thank you!
Thank you!
