Hi all,
I got F5-6000U3636E16GX2-TZ5RS and Asus ProArt Z690-CREATOR WIFI motherboard. The Memtest86 9.2 Free of XMP I and XMP II settings have failed. Only the Memtest86 9.2 Free of auto configuration has passed.
I wanna try the manual memory configuration. What memory configuration such as frequency, SPD, and so on should I use? Any suggestion?
Should I test the memory piece by piece? Since it is dual channel, I can run Memtest86 by inserting one memory piece into the motherboard. Or, the Memtest86 will only fail when two memory pieces are used?
Thanks.
Thanks.
