4x16 6000MHz kits?
  • 4x16 6000MHz kits?
    I'm wondering if we will see 4x16GB 6000MHz kits of the CL36 Trident Z5 RGB Silver?
    I have a ASUS Maximus Extreme Glacial with a 2x16GB kit but I've found myself needing more memory capacity.
    Adding two more sticks of the same wasn't a very good idea I was told. Atleast if I wanted the same speeds.
    Yes, eventually, however most platforms are not ready yet thus the reason they are not available yet. Once they are you should see them available for purchase.
      Currently the max supported frequency is a significantly lower, if you also use the secondary memory slots. That might improve later on, with further BIOS update, but could also be a platform or a motherboard limitation (at least in some cases).
        Thanks for the replies!
