Hi, I recently went into my Bios on my EVGA Z490 Dark MB and saw (by the way I have XMP on) that the Voltage was in Yellow color and was @ 1.41 Volts. Since Ram is rated to be 1.35 Volts. Should I be concerned.? I am not having issues with ram stability nor crashes & Game operate fine I do have a Intel i9 10900k Not OC. PC is working fine overall.
G Skill Trident Z Royal F4-4000C18D-32GTRS Voltage Question.
The memory kit is rated for 1.40V:
https://www.gskill.com/product/165/2...000C18D-32GTRS
So it sounds like the system is running as it should at full capability and stability. Yellow color is fine, just means the DRAM Voltage is higher than standard. For OC it can even be pushed into red.
- 1 like
