I'm building a new rig and facing challenge with memory. Setup is as follows
- Ryzen 2400G
- MSI B450 Tomahawk
- Corsair V650 PSU
To this added Trident Z RGB F4-320016D-16GTZR ( 2 Dimms of 8GB )
******************************************* I N S T A L L A T I O N **********************************************
First Day The install went fine. Rainbow colors. Booted without issue
XMP settings
- Tried to set XMP 2.0 .. long beeps on mobo
- reset bios
- booted fine
- realized bios is not updated
- updated bios
- set XMP profile 1 - runs fine at 2933 MHz
Mystic Light
- Installed latest version from MSI portal 3.0.0.19
- it is able to control mobo lights
- And it also able to control Trident Z
Subsequently I continue with my work to setup windows
Next Day
In Mystic Light I tried various combinations which were working. Although I did not pay attention to Dimms and their lights as I was not at all aware there could be any lighting issue
Later in the day I realize that Dimms are not lighting up. It was then I started reading and trying out fixes mentioned
**********************************************T R Y T H E F I X E S ************************************************* ******
What I have so far tried - Re-seated
- Change Slots
- Tried on another PC - I6700K / Asus Sabertooth Mk-1. Rams did not light up on boot - NOT Worked
- Unplugged power to drain any charge - NOT worked
- Mystic Light
- ----- Uninstalled, Reboot - NOT worked
- ----- Reinstalled, Reboot, Tried off, default , rainbow etc - NOT worked
- ----- Installed beta version 3.0.0.28 - NOT Worked ( This version is better in terms of memory and CPU usage than 3.0.0.19)
- GSKILL RGB Software
- ----- Uninstalled Mystic Light , Reboot, Install GSKILL sw v 1.06.68 , Reboot
- ----- Error - No Trident Z RGB modules found
****************************************** T H A I P H O O N B U R N E R ******************************************
Further reading revealed issue about SPD. So I downloaded the THAIPHOON Burner. It showed that
- CRC is OK on both A2/B2 dimms
- SPD is OK on both A2/B2 dims
At one point I had both mystic light + thaiphoon open. And I noticed changes to SPD info. Further probing it I realized
- When using OFF option in Mystic Light .... it would set the SPD same as reference SPD in Thaiphoon.
- When using RAINBOW (or say any other) option .. the SPD would not match the reference SPD .. and shows CRC error
To try this info, I set colors to OFF via Mystic and rebooted with a hope that RAM will pick up default setting on reboot. But it didn't work
*****************************************O F F ___ V S___ R A I N B O W **** A 2 SLOT ****************************************
Here are various screens from Thaiphoon
A2 Album https://imgur.com/a/wrNjJEv
A2 Read / Report
A2 CRC
*****************************************O F F___ V S___ R A I N B O W **** B 2 Slot ****************************************
B2 Album - https://imgur.com/a/I2qchJe
B2 Read / Report
B
2 CRC
Appreciate any suggestions on how to get my RAM LED working
