First off here is a link to my current setup...
https://pcpartpicker.com/b/pLsZxr
I have one stick that just won't cooperate with either Asus aura or gskill led softwares. It is stuck in the default rainbow animation. It is seated in the far left dimm slot closest to the processor. I have run memtest and it returned with no errors. I have also purchased Thaiphoon burner and read each stick which returned "crc ok" for all 4. I even used Thaiphoon burner to write the spd to each stick. I don't have cpu-z or cam installed currently as I know they conflict with Asus aura or Gskill's led software. All the other 3 modules work perfectly. Currently I just have the latest Asus Aura software installed. What else can I try at this point? I assume RMA is not an option as I have read thru the forums and Gskill doesn't want to own up to their mistake. Kinda sad if you ask me...
