Hello, everyone. I tried to change the color of my RAM today, but one of my sticks no longer changes no matter what I do. I've tried using both available versions of the beta software through multiple installs, swapped it into every DIMM, set my BIOS to default, and deleted all other RGB software. What else could I do to fix this? It's stuck in static mode with 5 different colors that I had picked before, but I wanted to change them all to green. My other stick is still working fine, besides having some weird issues where the software thinks I don't have any TridentZ RGB sticks, but swapping DIMM's helps that usually. Thanks in advance to anyone that helps!
CPU: R7 1700
MOBO: ASRock X370 Taichi
CPU: R7 1700
