I figured there is no dedicated thread for feature requests for the software so I figured I should just create one.
I have two requests to make.
1. Full Color wheel for all Modes.
In Static and in Breathing mode you have the color wheel + the triangle where you can adjust the colour you got from the colour wheel. I wish the triangle would be part in all modes.
2. Chaining of Rams.
Wouldn't it be cool to be able to chain your rams so that you can do like snake patterns, where your preferred lightning goes down the one stick, and then up the other or down one and then down the other? Just like if it was a chained LED strip.
