Trident Z RGB 3200 CL14 D.O.C.P. profile issue
  • Trident Z RGB 3200 CL14 D.O.C.P. profile issue
    Hi everyone,
    I have an issue with this ram, if I set the D.O.C.P. profile via bios the motherboard won't post and the pc keep resetting few times and then the bios return to the default options. I have a ryzen r7 1700, the 3200Mhz CL14 RGB kit and my motherboard is an asus prime x370-pro with the latest bios installed (0612). I know that other people with the same ram kit but without RGB can run it in D.O.P.C. profile just fine, I wonder why my pc can't handle the D.O.C.P. profile.
    P.S. I read about the problems with SPD corruption I already uninstalled Aura sync software but not Asus Ai suit 3, should I uninstall also this software? I checked my ram with thaiphoon burner and both the sticks are "CRC ok".
    Thanks for the help!!
    Hi! The XMP profiles section (SPD bytes 384 to 486) is not covered by CRC and can be verified visually.
      Hi! Sorry for the late responce but how can I verify these bytes?
      I also update the bios to the beta version (0803) and now the rams are running in D.O.C.P. profile without an issue.
        Read SPD with Thaiphoon Burner, click "Export" -> "Copy plain text to clipboard" and past here. I will check if SPD is corrupted.
          SOURCE SPD DUMP (1st ram)
          000 23 11 0C 02 85 21 00 08 00 60 00 03 01 03 00 00
          010 00 00 08 0D F8 03 00 00 6E 6E 6E 11 08 76 F0 0A
          020 20 08 00 05 00 A8 1E 2B 2E 00 78 00 14 3C 00 00
          030 00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36
          040 16 36 16 36 00 00 16 36 16 36 16 36 16 36 00 00
          050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          070 00 00 00 00 00 83 B5 CE 00 00 00 00 E7 C2 2D 24
          080 11 11 20 00 00 00 00 00 00 00 00 00 00 00 00 00
          090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C A0
          100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          140 04 CD 00 00 00 00 00 00 00 46 34 2D 33 32 30 30
          150 43 31 34 2D 38 47 54 5A 52 00 00 00 00 00 80 CE
          160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8E CF
          180 0C 4A 05 20 00 00 00 00 00 A3 00 00 05 80 00 00
          190 00 46 46 46 00 AA F0 F0 0A 20 08 00 05 00 C0 1C
          1A0 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          1B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          1C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          1D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          1E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          1F0 52 47 42 00 00 00 00 00 00 00 00 00 00 00 00 00
          SOURCE SPD DUMP (2nd ram)
            Here are the dump.. I deleted the various infos, thanks
              Mamaco, the second half of SPD array (bytes 100h-1FFh) of both your modules is not corrupted. Everything is OK.
                All right, thanks again!!
