Nah, they gave up. It's been 4.5 months since the last beta update. Dead software, they will never finish this product, we were all SCAMMED
[Trident Z RGB Software] Changelog (OUTDATED)
Download: TridentZ_RGB_v1.00.28.zip
Originally posted by Changelogv1.00.28
- Added AMD X399, Intel Z370 support.
- All LED lighting groups can now be independently controlled.Team HardwareLUXX | Show off your G.SKILL products!
GSkill obviously didn't fix the issue with Asrock boards with this new revision. The software still doesn't detect my 2 RAM sticks when in the correct slots. It's either fill it up with all 4, or have a buggy, unstable system with 2 in the wrong slots. Thanks.
"Out of beta". This software looks like it is in the alpha phase from a usability point of view.
1. DRAM1_1 DRAM1_2 ... all in a row that you need to scroll through? Seriously?
My proposal : Group the leds per dimm. Also add functionality to sync the colours select for one dimm to a select amount of others.
2. Sometimes white is not displayed as white but as the color select on the wheel around the triangle.
3. White is not selectable in all modes. (Should be easy to add, but you would have to get rid of the colour wheel)
4. No daisy chaining for automatic effects. (E.g. Let the comet run through DIMM A then DIMM B
At the moment this has really the look and feel of a proof of concept. 1 year after the release of the Trident Z RGB. It is not necessary to add new effects yourself. An API and SDK would improve the possibilties of this software so much!
Rant is over now.
The software itself seems to work fine by now. No manual deinstallation needed, and no problems at all. Thanks for that! I really really hope you continue to improve the software as it will also greatly improve your product, and might even regain customers that you probably lost by the terrible experience during the last year!
New msi bios fix
First let me just say I have had a lot of trouble with these ram sticks. I have spent hours of installing and uninstall software and more restoring my computer so not to leave any trace of failed ad temps, of getting these to work correctly. I have had one of these kits RMA ed, and even moving RAM slots around to try and correct or elimate possible problems. I received my replacement sticks over 2 months ago and have suffered with default rainbow for that same time. Although I support Gay rights it looks terrible in a black HAF X case with RED themed lights around them. LOL .....
But thankful MSI have stepped in with a Bios update /'
Version
7A78v18
Release Date
2017-11-23
File Size
7.18 MB
Installing this update will support the GSKILL TRidentZ Ram allowing you to take control of the Ram Leds
My specs
MB Z270 MSI M5
OS WIN7 64 BIT
SSD Crucible 275GB
GPU MSI 1060X 6GB
CPU KABYLAKE 7700K
thanks
Originally posted by jarrod View PostFirst let me just say I have had a lot of trouble with these ram sticks. I have spent hours of installing and uninstall software and more restoring my computer so not to leave any trace of failed ad temps, of getting these to work correctly. I have had one of these kits RMA ed, and even moving RAM slots around to try and correct or elimate possible problems. I received my replacement sticks over 2 months ago and have suffered with default rainbow for that same time. Although I support Gay rights it looks terrible in a black HAF X case with RED themed lights around them. LOL .....
Version
7A78v18
Release Date
2017-11-23
File Size
7.18 MB
My specs
MB Z270 MSI M5
OS WIN7 64 BIT
SSD Crucible 275GB
GPU MSI 1060X 6GB
CPU KABYLAKE 7700K
thanks
