Will 4 modules of Ripjaws V (F4-3200C16D-16GVKB) run well on 3200MHz and C16?
  • Will 4 modules of Ripjaws V (F4-3200C16D-16GVKB) run well on 3200MHz and C16?
    I own one kit and plan to get another one.
    https://www.gskill.com/product/165/1...200C16D-16GVKB
    CPU: Ryzen 5 5600
    Mobo: MSI B450 Gaming Plus Max
    Each memory kit is designed to be used on it's own. You would need test and see how well two separate kits may work together since they were not done so from factory. Ideally a single 32GB+ kit should be used to replace the existing memory kit.
