Trident Z Neo Failed Memtest86
  • Trident Z Neo Failed Memtest86
    My PC has been blusescreening lately and after running diagnostics I received this result with Memtest86
    I don't know what most of this means but I do know that a big FAIL message came up indicating memory issues
    System Information
    EFI Specifications 2.70
    System
    Manufacturer ASUS
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Vendor American Megatrends Inc.
    Version 0321
    Release Date 02/21/2020
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name TUF GAMING Z490-PLUS (WI-FI)
    Version Rev 1.xx
    Serial Number 200366272602785
    CPU Type Intel Core i5-10600K @ 4.10GHz
    CPU Clock 4156 MHz [Turbo: 4611.0 MHz]
    # Logical Processors 12 (6 enabled for testing)
    L1 Cache 4 x 64K (211670 MB/s)
    L2 Cache 4 x 256K (91688 MB/s)
    L3 Cache 12288K (37503 MB/s)
    Memory 32674M (21774 MB/s)
    RAM Configuration DDR4 3600MT/s / x2 Channel / 16-19-19-39 / 1.200V
    Number of RAM SPDs detected 4
    SPD #0 8GB DDR4 XMP 1Rx8 PC4-28800
    Vendor Part Info G Skill Intl / F4-3600C16-8GTZNC
    JEDEC Profile 2134MT/s 15-15-15-36 1.2V
    XMP Profile 1 3602MT/s 16-19-19-39 1.35V
    SPD #1 8GB DDR4 XMP 1Rx8 PC4-28800
    SPD #2 8GB DDR4 XMP 1Rx8 PC4-28800
    SPD #3 8GB DDR4 XMP 1Rx8 PC4-28800
    Number of RAM slots 4
    Number of RAM modules 4
    DIMM A1 8GB DDR4 1Rx8 PC4-17000
    Vendor Part Info G-Skill / F4-3600C16-8GTZNC / 00000000
    SMBIOS Profile 2133MT/s 1.2V
    DIMM A2 8GB DDR4 1Rx8 PC4-17000
    DIMM B1 8GB DDR4 1Rx8 PC4-17000
    DIMM B2 8GB DDR4 1Rx8 PC4-17000
    Result summary
    Test Start Time 2024-09-09 14:43:12
    Elapsed Time 0:02:14
    Memory Range Tested 0x0 - 85E000000 (34272MB)
    CPU Selection Mode Parallel (All CPUs)
    CPU Temperature Min/Max/Ave 42C/47C/44C
    Lowest memory speed 3600 MT/s (16-19-19-39)
    Highest memory speed 3600 MT/s (16-19-19-39)
    # Tests Completed 4/48 (8%)
    # Tests Passed 1/4 (25%)
    Lowest Error Address 0x70030F3C (1792MB)
    Highest Error Address 0x7BF7A7E70 (31735MB)
    Bits in Error Mask FFFFFFFF9D7EDFBD
    Bits in Error 56
    Max Contiguous Errors 2
    CPUs that detected memory errors { 0, 2, 4, 6, 8, 10 }
    Bits in Error
    x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x . . x x x . x . x x x x x x . x x . x x x x x x . x x x x . x
    63 0
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 1/1 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 0/1 (0%) 269
    Test 2 [Address test, own address] 0/1 (0%) 276
    Test 3 [Moving inversions, ones & zeroes] 0/1 (0%) 3426
    Test 4 [Moving inversions, 8-bit pattern] 0/0 (0%) 6029
    Test 5 [Moving inversions, random pattern] 0/0 (0%) 0
    Test 6 [Block move, 64-byte blocks] 0/0 (0%) 0
    Test 7 [Moving inversions, 32-bit pattern] 0/0 (0%) 0
    Test 8 [Random number sequence] 0/0 (0%) 0
    Test 9 [Modulo 20, ones & zeros] 0/0 (0%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/0 (0%) 0
    Test 13 [Hammer test] 0/0 (0%) 0
    Last 10 Errors
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF69323C, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF69317C, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF693174, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF69313C, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF692F74, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF692C74, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF692C24, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF692B3C, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF692B2C, Expected: 7F7F7F7F, Actual: 7F7F7F77
    2024-09-09 14:45:26 - [Data Error] Test: 4, CPU: 8, Address: 4FF692B24, Expected: 7F7F7F7F, Actual: 7F7F7F77
    Send them in for warranty inspection / exchange to see if a replacement kit can work better:
    https://www.gskill.com/rma-policy
