Compatibility issue with G.SKILL RIPJAWS 16X2 32GB 3200MHZ on MSI B550M PRO VDH WIFI
  • Compatibility issue with G.SKILL RIPJAWS 16X2 32GB 3200MHZ on MSI B550M PRO VDH WIFI
    Is the G.SKILL RIPJAWS 16X2 32GB 3200MHZ compatible with MSI B550M PRO VDH WIFI ? Because when we tested various Number of MSI B550M PRO VDH WIFI with G.SKILL RIPJAWS 16X2 32GB 3200MHZ is having random shutdown and game crashes. This issue is not happened in the past. But, On recent days numerous cases with this issue occurred. If anyone facing this issue or know solution to this issue. Please let me know.
    ( Assuming you are talking about the F4-3200C16D-32GVK: )
    According to the QVL it is indeed compatible, as long as a Ryzen 3000 processor or a Ryzen 5000 APU / processor is used.
    https://www.gskill.com/qvl/165/184/1...C16D-32GVK-QVL
    Issues with certain configurations could be tied to a newer BIOS version or kits with a specific DRAM type. A workaround for the former is to downgrade the BIOS to an older version, that is known to work with that SKU. The latter can be confirmed by comparing the lot codes on the warranty stickers of the affected kits.
    It is probably recommendable to at least check each of the modules for errors with MemTest86 beforehand, to rule out or identify defective ones. That could also be done using a different motherboard from the QVL.
