My computer has started freezing so I ran memtest 86:
Summary
System Information
Result summary
Bits in Error
I tested each individually afterwards. The first two were fine, but the third had 6 errors, the fourth had 30 and I stopped the test early. Is there anything I can do with the bad sticks?
Summary
Report Date | 2024-07-26 15:08:38 |
Generated by | MemTest86 V11.0 Free (64-bit) Visit MemTest86.com to Upgrade to Pro |
Result | FAIL |
EFI Specifications | 2.70 |
System | |
Manufacturer | Micro-Star International Co., Ltd. |
Product Name | MS-7C37 |
Version | 1.0 |
Serial Number | To be filled by O.E.M. |
BIOS | |
Vendor | American Megatrends Inc. |
Version | 1.80 |
Release Date | 04/20/2020 |
Baseboard | |
Product Name | MPG X570 GAMING EDGE WIFI (MS-7C37) |
Version | 1.0 |
Serial Number | J716058912 |
CPU Type | AMD Ryzen 9 3900X 12-Core |
CPU Clock | 3800 MHz [Turbo: 4488.1 MHz] |
# Logical Processors | 24 (16 enabled for testing) |
L1 Cache | 24 x 64K (246437 MB/s) |
L2 Cache | 24 x 512K (92906 MB/s) |
L3 Cache | 1 x 65536K (20050 MB/s) |
Memory | 32730M (19079 MB/s) |
RAM Configuration | DDR4 3600MT/s / x2 Channel / 16-16-16-36 / 1.200V |
Number of RAM SPDs detected | 4 |
SPD #0 | 8GB DDR4 XMP 1Rx8 PC4-28800 |
Vendor Part Info | G Skill Intl / F4-3600C16-8GTRG |
JEDEC Profile | 2134MT/s 15-15-15-36 1.2V |
XMP Profile 1 | 3602MT/s 16-16-16-36 1.35V |
SPD #1 | 8GB DDR4 XMP 1Rx8 PC4-28800 |
SPD #2 | 8GB DDR4 XMP 1Rx8 PC4-28800 |
SPD #3 | 8GB DDR4 XMP 1Rx8 PC4-28800 |
Number of RAM slots | 4 |
Number of RAM modules | 4 |
DIMM A1 | 8GB DDR4 1Rx8 PC4-28800 |
Vendor Part Info | Unknown / F4-3600C16-8GTRG / 00000000 |
SMBIOS Profile | 3600MT/s 1.2V |
DIMM A2 | 8GB DDR4 1Rx8 PC4-28800 |
DIMM B1 | 8GB DDR4 1Rx8 PC4-28800 |
DIMM B2 | 8GB DDR4 1Rx8 PC4-28800 |
Test Start Time | 2024-07-26 11:05:20 |
Elapsed Time | 3:53:19 |
Memory Range Tested | 0x0 - 81F300000 (33267MB) |
CPU Selection Mode | Parallel (All CPUs) |
CPU Temperature Min/Max/Ave | 45C/77C/59C |
RAM Temperature Min/Max/Ave | |
TSOD0 | 37C/46C/42C |
TSOD1 | 39C/49C/45C |
TSOD2 | 39C/49C/44C |
TSOD3 | 38C/47C/43C |
Lowest memory speed | 3600 MT/s (16-16-16-36) |
Highest memory speed | 3600 MT/s (16-16-16-36) |
# Tests Completed | 48/48 (100%) |
# Tests Passed | 44/48 (91%) |
Lowest Error Address | 0x1FBD29CAC (8125MB) |
Highest Error Address | 0x79FFD9CEC (31231MB) |
Bits in Error Mask | 0000000000008500 |
Bits in Error | 3 |
Max Contiguous Errors | 1 |
CPUs that detected memory errors | { 0, 7, 8, 13, 15 } |
. | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | x | . | . | . | . | x | . | x | . | . | . | . | . | . | . | . |
63 | 0 |
Test | # Tests Passed | Errors |
Test 0 [Address test, walking ones, 1 CPU] | 4/4 (100%) | 0 |
Test 1 [Address test, own address, 1 CPU] | 4/4 (100%) | 0 |
Test 2 [Address test, own address] | 4/4 (100%) | 0 |
Test 3 [Moving inversions, ones & zeroes] | 4/4 (100%) | 0 |
Test 4 [Moving inversions, 8-bit pattern] | 4/4 (100%) | 0 |
Test 5 [Moving inversions, random pattern] | 4/4 (100%) | 0 |
Test 6 [Block move, 64-byte blocks] | 4/4 (100%) | 0 |
Test 7 [Moving inversions, 32-bit pattern] | 4/4 (100%) | 0 |
Test 8 [Random number sequence] | 0/4 (0%) | 6 |
Test 9 [Modulo 20, ones & zeros] | 4/4 (100%) | 0 |
Test 10 [Bit fade test, 2 patterns, 1 CPU] | 4/4 (100%) | 0 |
Test 13 [Hammer test] | 4/4 (100%) | 0 |
Last 10 Errors |
2024-07-26 14:21:59 - [Data Error] Test: 8, CPU: 8, Address: 79FFD9CEC, Expected: CB7A552E, Actual: CB7A512E |
2024-07-26 13:16:03 - [Data Error] Test: 8, CPU: 0, Address: 43C3F9CAC, Expected: 6B88D254, Actual: 6B88D354 |
2024-07-26 13:15:25 - [Data Error] Test: 8, CPU: 15, Address: 1FBD29CAC, Expected: C0114C56, Actual: C011CC56 |
2024-07-26 12:12:03 - [Data Error] Test: 8, CPU: 13, Address: 688096BAC, Expected: E6E39E81, Actual: E6E39A81 |
2024-07-26 12:11:18 - [Data Error] Test: 8, CPU: 7, Address: 42288C46C, Expected: 2FEF4D58, Actual: 2FEF4C58 |
2024-07-26 11:16:16 - [Data Error] Test: 8, CPU: 7, Address: 3D845972C, Expected: 9D7C4B22, Actual: 9D7CCB22 |
