Since 2021 I have been running the MSI Tomahawk B550 with a set of G.Skill F4-3600C16D-32GTZR memory, a total of 32 GB at 16-16-16-36 timings (no overclock). This is using the built in XMP-1 profile. I have had not a single issue. Using slots 2 and 4 on the motherboard.
Today I swapped the ram for basically the same, but 64 GB this time, the F4-3600C16D-64GTZR ram kit. Same slots 2 and 4 on the mobo. But now it won't boot to BIOS. The screen stays black and the first EZ led is burning red, which apparently means a CPU issue.
However, when I swap the ram back to the 32 GB kit, I can boot again and there are no issues.
What can I do to fix this? It stands to reason if the F4-3600C16D-32GTZR is supported, so should the F4-3600C16D-64GTZR.
