These 2 sticks of memory are less than 6 months old. It's been in use about 4 months actually (built remotely then used hard starting in early March). They have periodically failed one of the tests the system runs regularly (randomly - fails one test one time, fails a build the next time, 2 tests the time after, etc). Most of these failures have been single bit errors and not the same bit either. The errors have been getting to the point where the machine is mostly unusable and is starting to corrupt disk data as broken memory gets written out. We fired up a memory test on it yesterday and it just went nutz with errors. Enclosed is a screen shot of that run. We are unfortunately past the point I can RMA to newegg. In order to get manufacturer RMA I was told I needed to post in this forum. Is there anything else I need to do?
F4-3200C16d-32DVR (2x16GB) fails memtest
