GIGABYTE Z690 UD DDR4 & Ripjaws V DDR4-4400MHz CL19-26-26-46 1.50V 64GB (2x32GB)
  • GIGABYTE Z690 UD DDR4 & Ripjaws V DDR4-4400MHz CL19-26-26-46 1.50V 64GB (2x32GB)
    Does anyone know if Ripjaws V DDR4-4400MHz can run at 4400Mhz on GIGABYTE Z690 UD and 12900k? Are there going to be stability issues? Or should I wait for DDR5? I believe 12900k supports max 3200mhz DDR4. So I am not sure if the computer would be freeze or something.
