I recently completed a new build, which contains the G.SKILL RIPJAWS V DDR4-3600 (2x8GB) RAM, and I felt I needed more memory because most of the work I was doing was using up a high percentage of it, which I underestimated.
This is the product in particular from Newegg: https://www.newegg.com/g-skill-16gb-...82E16820232880
I'm not completely tech savvy, but from what I understand, mixing memory is considered one of the worst mistakes you could perform when installing RAM. I was wondering if it's possible to purchase the same product, but in 2x16GB or 2x32GB form, and placing them in the 2 free slots for my MOBO, effectively using all 4 slots, and have it perform normally? Unsure if it would be as bad as it's typically projected to be, since it would be the same series and speed, just different memory capacity.
My motherboard for reference is the ASUS TUF GAMING B550M-Plus (No-WiFi)
Apologies if this is a doomed idea from the start, like I mentioned previously, I'm not entirely familiar with just how many things could go wrong with an idea such as this one.
