F4-3600C16D-64GTZR compatibility with Ryzen 9 3900X on X570 AORUS MASTER
  • F4-3600C16D-64GTZR compatibility with Ryzen 9 3900X on X570 AORUS MASTER
    I have bought F4-3600C16D-64GTZR DDR4 64GB (2x32GB) TridentZ RGB
    3600MHz CL16 XMP2 16-22-22-42 memory.
    They did not come to me yet, but I am worried that they will not be
    working properly on 3600MHz profile with my Ryzen 9 3900X on X570
    AORUS MASTER motherboard.
    This model of RAM is on AMD X570 (Ryzen 5000 series CPUs) list but not
    AMD X570 (Ryzen 3000 series CPUs) list on G.Skill website.
    BTW Are these F4-3600C16D-64GTZR on the Samsung b-die?
    Please advise.
    Compatibility should be no problem, but you will need to test to see if the system can stabilize DDR4-3600 natively. If not, try DDR4-3400 or 3200 to see what it can do. From a stable point, check CPU SoC Voltage then manually set it higher to see if you can stabilize a higher DRAM Frequency.
    IC and PCB can vary with batch so you will need to check with utility software to see what you get in hand.
      Retail kits consisting of 32GB modules like that have to built from 16Gbit ICs. So Samsung 8Gbit B-die are out of the question for them.
