Is it possible to upgrade memory to E15 20RD, from 16GB to 32GB using Ripjaws ?
In some places it says the maximum memory for this computer is 16GB,
and in Lenovo PDF it says:
"Max Memory[1]
Up to 16GB DDR4-2666
Notes:
The max memory is based on the test results with current Lenovo memory offerings. The system may support more memory as the
technology develops."
(see https://psref.lenovo.com/syspool/Sys...d_E15_Spec.PDF )
There are some websites that sell 32GB specific for this computer, and call it "over RAMing",
but these are non-branded memory, eg:
https://www.phs-memory.com/computer-...-sp330794.html
I prefer to buy from a known brand, and I have gskill Ripjaws in my local store.
Do you know if this will work ?
I don't know what specs to check in the memory.
Thanks for any help,
or anyway I can check this
(except buying and trying out, because if it worn work I cant return it to store)
Regards,
iksi
"Max Memory[1]
Notes:
Regards,
iksi
