Trident RAM ARGB 3200mhz
Trident RAM RGB will change colors or simply go off after plugging in or unplugging a USB device. I also have Gigabyte Fusion installed, and with the Fusion software window opened, I can see that unplugging/plugging a USB device causes Fusion to refresh itself, as if I had just started it.
I uninstalled Fusion and Trident software.
Before I did that, plugging or unplugging a USB device caused the Fusion controlled ARGB/RGBs to blink off and on quickly once, or sometimes change color. Then they would slowly change back to the original color set in Fusion. As of now, I'm not getting the blinking off and on problem with the Fusion controlled lights, but only the Gskill ARGB problem.
Uninstalling Fusion and reinstalling it did NOT fix the fast blink off and on problem. However, after uninstalling Gskill Trident and reinstalling, the fast off on blink for the fusion controlled lights is fixed.
