Hi guys,
So, I actually tried contacting G.Skill Euro tech support, and after 2 weeks, got a reply so bad, it was insulting. I asked many questions in my email, and they literally answered with 1 sentence.
So yeah, the kit above, has "Ryzen compatible" printed on the box, but as far as I've researched (HOURS spent trawling through motherboard makers like MSI/Gigabyte etc) and checking individual motherboard models for compatibility with this particular model, I was amazed to find ZERO boards supported this RAM. None at all!
So why does it have "Ryzen compatible" on the box? As that's a lot like writing Ferrari on a tractor tyre, selling it, advertised as *Ferrari compatible,* knowing there's no wheel that'd fit the tyre, to fit on that car?
My reason for INSISTING on compatibility and help in this instance, is because, like G.Skill tech support being REALLY rude, ASUS are exactly the same, saying they don't even want to talk to me unless my RAM is on their QVL list. I want to RMA my board ASAP, because its cheap, nasty, overpriced, the RAM latches don't even work, the mobo battery won't release easily, and I've lost my faith in Asus who told me to RMA the board instead of helping me.
So will you help me G.Skill this time around? As I want to know why 4 sticks of RAM makes an ASUS B550 A Gaming motherboard, fail to post bios. The RAM LED bug will light up on the board, the RAM will light up, but BIOS does not post. This is a really common problem, and there doesn't seem to be a fix, I've seen it reported on X570 and B550 from Asus, MSI and Gigabyte boards. Sure I expected some issues with a 4 dimm packet, but how can I work things out when the BIOS won't even load? Once it happens, nothing will allow the board to even start up again, requiring the CMOS being cleared.
It just feels like a little bit of a con really, as this is Samsung B-die I'm using here with a 5600X. 2 sticks will boot up fine and run in DOCP mode, but 4 sticks, board won't even start. Why does this happen? Every reviewer out there on Youtube has skipped over this, using ridiculously rare 3200 CL14 kits, 4 x 8gb dimm kits, failing to tell people anything else will give people headaches over even booting.
What motherboard can you recommend for this RAM kit, that's list this RAM on its motherboard manufacturers QVL list? As I already know, there's a huge difference between your QVL list, Pangoly's QVL list, and the QVL for the specific motherboard from the manufacturer.
Also, I gotta mention, the RAM feels kinda crunchy and creaky? The heatsink and light bar on top just doesn't feel very secure.
