Temperatures of tridentZ
  • Temperatures of tridentZ
    Hello, just bought TridentZ RAM 2x8GB "F4-3600C16D-16GTZ", tryed overlocking and it was like 46 degrees temperature at stress test, also i heard from one youtube guy dont make more that 45, than i made default setting of bios and start playing games and in games even on default it also 46-47 degrees. So question is what is normal temperatures for this ram to not brake it and working it like stable.
    Memory modules can handle much higher so they will be fine.
      I get 38 right stick and 44 left stick, but I have a 120mm fan turned towards the RAM. Otherwise up to 55 should be fine not to affect stability. And for them not to die it is much more, up to 80°C.
