Anyone have experience using F4-4000C18D-64GTZR kit on AMD Zen 3 rig?
  • Anyone have experience using F4-4000C18D-64GTZR kit on AMD Zen 3 rig?
    I'm looking to use this kit with an 8- or 12-core Zen 3 cpu on an ASRock X570 Taichi motherboard. Specifically, hoping to hit 18-18-18-38 1T using FCLK=2000MHz (FCLK that high depends heavily on cpu silicon quality, I know :-)). Any info like AIDA64 bw/latency or Typhoon screenshots would be helpful.
    Also, what memory IC's is this kit using?
    Link to kit: https://gskill.com/product/165/166/1...0V64GB-(2x32GB
    That is not a certified combination so you will need to test and see what the combination can do together. If you have not purchased yet, we recommend using a kit listed on the G.Skill RAM Configurator for guaranteed results:
    https://www.gskill.com/configurator?...GB%20(32GBx2),
      Can you tell me more about the memory chips used on this kit, like manufacturer and die type?
