Dear experts,
when I got the MB I couldn't find 16GB RAM modules. So I started with 4x8GB F4-3200C14Q-32GTZ.
This kit was running fine at 3400 MHz (actually 1700, double data rate)
Later I needed more RAM and bought another 4x kit: F4-3200C14Q-64GTZ, which is also on the QVL from ASUS now.
What is the best way to install these modules?
At the moment I have the 4x16 modules in A1, B1, C1 and D1 and the 4x8 modules in A2, B2, C2 and D2.
But so far I only managed to run the RAM at 3000 MHz.
I had to increase the current rating for CHA/B and C/D from 100%. Didn't start with the default. Currently using 140%
Is this the best configuration in terms of performance and stability, or should I e.g. use: 4x16GB in A1, A2, B1 and B2 and 4x8 in C1, C2, D1 and D2 (or the other way around)?
I understand that ideally I should have bought a 8x16GB kit, but I didn't want to throw away the existing 32GB RAM.
Regards,
Andreas
Regards,
Andreas
