hi, in asrock z490 taichi memory QVL say F4-4133C19Q-32GTZKKF only 2 DIMM socket support is it means only 2 memory stick of 4 in kit will work at 4133mhz? tnx
F4-4133C19Q-32GTZKKF and AsRock z490 taichio
That is how I understand it as well.
G.SKILL currently only lists dual kits of that frequency as compatible with the Z490 Taichi, so the secondary slots probably have a lower frequency cap. So with four sticks you might have to reduce the frequency a bit. That might change/improve with future BIOS release, though.
