I'm using the latest version of the software, having upgraded to 2x16 Royals I no longer have the "no modules found" issue but now there seems to be a CPU consumption issue that builds over time. When I first start the PC hid.exe is only using .25% but after a few hours, maybe 6 hours or so, hid.exe is now consuming ~8.5%! This is with i7 8700k. To put this in perspective, RGB Fusion stays at .25%, Logitech G-Hub is .02%, Google Chrome with literally 40+ tabs open = .25%. hid.exe is 8.5%, it's so high that I need to periodically check on it in process explorer and disable it before gaming. If I terminate hid.exe and re-launch G.Skill software it will create a new hid.exe process at normal CPU consumption (.25%) but after that it quickly goes up to 8.5%, it may take an hour or two and then I have to do it again, and again, and again.
Please fix this issue.
Z370
i7 8700k
Z370
i7 8700k
