Currently problem is with a z570 Aorus Ultra with bios 12e and 2 sticks of 2x16 gskill ram it runs and boots at base speed but if i use the xmp profile sound has weird artifacting and the computer eventually restarts without a bsod, also using a Ryzen9 3900x.
Tried windows mem test it passed,tried bumping voltages,been reading a lot of forums and tried most of them.
HwInfo Summary.
https://gyazo.com/094bf20d1f25a18f0586e29cb26db8b0
the ram is on the QVL list for the motherboard and the motherboard is on gskills site as OVL as well so both sites say this ram should work
the 4 sticks of corsair vengance 4gb 3000 work fine in XMP.
This is also a fresh build new install of windows and all newest drivers. was using the corsair for about a week till the gskill showed up.
2 sticks are installed in the recommended a2 and b2 on the board
*Update mar 31st: Been running stock speeds now with no sound artifacting or anything for hours now stable (build is only about a week or 2 old)
*update apr 1: pulled both sticks out blew out the slots and reseated to make sure they were in serial order, went to 3400 and 1.2v without turning on xmp (little weird) then it was semi stable (more than it has been) so i upped the voltage to 1.35 and 3600mhz a lot more stable than day 1 upped the voltage to 1.4 after running into some more sound issues which is usually what goes before it crashes from the ram seems more stable but still having some usb glitches, which is what it was doing on the first day.
Corsair headset just started connecting and disconnecting as of writing all this.
seen other posts where your techs recommend upping the dram voltage to 1.45 wondering if i should try to bump it to there since more voltage has seemed to stabilize it, just don't want to fry anything since everything is new.
Updated HW info summary.
https://gyazo.com/ac9093320e2b3d09d4c11c2bbf9b8467
HwInfo Summary.
