So this is my 2nd set of a Gskill memory kit to go south. I have the 2 GSkill Flare X F4-3200C14D-16GFX kit and went to turn on my computer and no post, I took out one set and and it booted right up. I switched them around in the same slots and the other kit wouldn't even post. So I tested it by the stick and one stick would post while the other stick would not. The only conclusion I can come to is a bad stick. I find it hard to believe that I have now had 2 kits of the same memory go bad, the 1st one I RMA'ed to Newegg. I already filled out and sent a RMA form with GSkil.
I also am running these at XMP profile, no overclocking whatsoever.
Gigabyte X470 Gaming 5
AMD 3900X
2 kits o f GSkill Flare X F4-3200C14D-16GFX
MSI 1080 GTX
AMD 3900X
MSI 1080 GTX
