Ddr4 3200mhz cl14 dual rank
  • Ddr4 3200mhz cl14 dual rank
    Hello. Please let me know which ddr4 3200 cl14 it is dual rank. I need 32gb 8x4 for quad channel.
    You can post all of them. Thank you.
    https://www.newegg.com/p/pl?d=gskill...0546709%208000
      Just to add to that: All of the 4x8GB Kits consist of four single rank modules, because they are built from a very specific 8Gbit DRAM IC type. So if you want dual rank modules of that type, you need to instead look for 16GB modules and 4x16GB kits with the same specification of DDR4-3200 CL14.
        All of this are dual rank or single rank?
          Look at the website sent by gskill tech
            These are dual rank:
            https://www.newegg.com/p/pl?d=gskill...61%20600546709
