Hello there.
I have some problems with using the mentioned ram on my motherboard. It works on 3000 mhz when i enable XMP ...but everytime i shut down my computer it won't boot normally,it runs a few seconds then shuts off.
(Im using the 2x8GB kit 3000 mhz)
It shows the motherboard logo all fans and everything boots up normally and then just shuts off . I think it's called cold start problem.
So i would like to get some advice about it...should i set the DDR voltage from 1.35 to 1.40 to prevent that or is there something else i can do??
Thanks!
Thanks!
