I need to upgrade my RAM from 16GB to 64GB, and the more I read into this the more complicated it is becoming.
If I purchase 2x kits of Flare X 32GB (2x16) @ 2400 will I have compatibility issues? and will it run at 2133 only?
Or should I just play it safe and get 1x kit of Flare X 64GB (4x16) @ 2133? This is the kit that G. Skill RAM configurator says is compatible with my system but is unnavailable here in Australia (I can't find it anywhere). Plus the 2x kits of 32GB is the cheaper option.
My system is; AMD Ryzen 7 1700, ASRock, Fatality AB350 Gaming K4
Currently have 2x 8GB RAM @ 2133
