ASRock Motherboard/G.Skill Aegis Memory Compatibility
  • ASRock Motherboard/G.Skill Aegis Memory Compatibility
    I have a ASRock Fatal1ty AB350 Gaming K4 with an AM4 socket and AMD Promontory B350 chipset. I have an AMD Ryzen CPU. The MB/CPU combination supports up to 3200+ (OC) memory.
    The memory I purchased is G.Skill Aegis DDR4 F4-2800C17D-16GIS (2 x 8GB).
    The combo doesn't appear on compatibility lists but I see warnings that those lists may not be complete.
    Is this memory & MB combination compatible? I don't want to open the memory package until I know I can use it.
    Thanks!
    Here is the G.Skill QVL for that motherboard:
    https://www.gskill.com/en/configurat...952&model=2989
    We have only tested these kits to be fully certified
