Best/Fastest (3600+) Quad Kit for Ryzen Threadripper 1950X / ASRock Fatal1ty X399 MB
  • Best/Fastest (3600+) Quad Kit for Ryzen Threadripper 1950X / ASRock Fatal1ty X399 MB
    There doesn't seem to be a lot of good info out about this, but I'm trying to find the fastest quad memory kit for the new Ryzen ThreadRipper 1950X (paired with a ASRock Fatal1ty X399 Mobo). This CPU/Mobo Combo says it can handle 3600+ DDR4, but I haven't found anything marketed for this yet. Even the GSkill Flare X doesn't seem to have any kits this fast. I did see a lot of youtubers and other builders using some of the Trident kits to accomplish this.
    Anyway, I'm hoping this could serve as a good thread to post successful / compatible Quad Memory Kits for the ThreadRipper series and hopefully for this ASrock Mobo.
    This seems to be the best available kit for the Flare X series, but it's only rated at 3200? I'm not sure if it has an XMP profile to OC up to 3600? It does seem like you have to stick with the 8GB modules (x4) in order to hit the higher OC rates.
    [Flare X (for AMD)] F4-3200C14Q-32GFX
    DDR4-3200 (PC4-25600)
    32GB (8GBx4)
    CL14-14-14-34
    1.35 Volt
    https://www.gskill.com/en/configurat...073&model=3075
    The Taichi board is slightly better for higher capacity an frequency, so that is something you can consider if you would like that.
