I have GSkill TridentZ RGB F4-3600C16D-16GTZR tightened to 14-14-14-34 T1 and would like to try some tight settings on the secondaries..So far I have TRFC down to 300 from 535,and TREFI was on Auto at 11400 x3 and now at 34200..Are there any other secondary ones I should focus on to tighten up..I was told at another site that TRTP, TRRD, TFAW, TCWL are good ones to start..Are there any others that are worth tightening..
Tighten GSkill TridentZ RGB F4-3600C16D-16GTZR
You might see bigger performance gains from tightening the tertiaries, esp if your board failed to properly train them.Team HardwareLUXX | Show off your G.SKILL products!
Most things from XA's guide are still valid: http://forum.hwbot.org/showthread.php?t=161483Team HardwareLUXX | Show off your G.SKILL products!
