register
I recently bought additional 2 more RGB ram it seems like the light is not working at all. Please help! Does anyone have any solution to it ? out of the 4 RGB ram , only 1 is not working ...
Within the software, turn lighting OFF/ON a couple times to see if that can revert settings to default rainbow. Another method is to uninstall the program, remove any folders, restart the system, reinstall everything and try again.
If problem persists, completely remove the G.Skill software and try this one:
I'm using G.skill software to control my RGB lighting. Yes its the latest BIOS. I've tried numerous time but still cant get the only stick to light up. i cant use asus software , it keeps on crashing whenever i launch it.
im currently using MSI Z270 Gaming M7 as my motherboard.
