Hi, i have an issue when im trying to run F4-2400C15D-16GRR with 2400 in XMP Profile.
Im using this MB (X99 chipset): GA-X99-Ultra Gaming
http://www.gigabyte.us/Motherboard/G...10#support-doc
the default value that boot is : 2133Mhz.
CPU: Intel Xeon Processor E5-2699 v4.
but whatever i did wasn't booted to windows with 2400Mhz, seems that the MRC training failed.
tried XMP enabled, and even ramped the voltage up to 1.3, noting helps.
i tried the recommended configuration for the dual DIMMs , not boot.
so next i tried only with single DIMM, not boot.
Combination 1: [A][ ][ ][ ] [CPU] [ ][ ][ ][ ]
Combination 2: [ ][A][ ][ ] [CPU] [ ][ ][ ][ ]
Combination 3: [ ][ ][A][ ] [CPU] [ ][ ][ ][ ]
Combination 4: [ ][ ][ ][ ] [CPU] [ ][A][ ][ ]
Combination 5: [ ][ ][ ][ ] [CPU] [ ][ ][A][ ]
Combination 6: [ ][ ][ ][ ] [CPU] [ ][ ][ ][A]
I couldn't reach the slots that close to the CPU because the cooling system was blocking it (if you tell me to do so i will remove it and try).
My BIOS is latest (F6).
https://drive.google.com/open?id=0B0...ENYeWNXMmhBVlU
https://drive.google.com/open?id=0B0...G1xWGQ2bGJjT3c
https://drive.google.com/open?id=0B0...0VzZHpwVEtzUTA
im adding some pictures of the timing that the system recommend.
please take a look and see if something with the timing is wrong?
