I might have discovered the wheel again !
Like my self and others that have problems with with the trident z RGB serie and the softwares Trident z RGB or asus aura that also controles the lights on the ram..basicly these 2 programs looks like the same and i think they are the same.
The ram works fine but when it comes to the RGB lights and the software, then all hell is loose.
Software crashed..ram lights dont respond..ect. (Error things like this)
I used the thaiphoon program and scanned my ram and it turned out they have crc error in sectors that that somehow controles the lights.
And each time i was scanning each ram stick, then i got different crc error
I tryed to disable all programs i dident need to run in start up.
And then i found out in my case it was the corsair link software that messed up the crc error..when i exit the corsair link program and scan my ram again they show report of CRC OK.
Even the RGB software from asus aura reponds on my commands and dosent freeze or crash. Until i start the corsair link program..
Now i have 6 corsair HD 120 mm RGB fans installed on a corsair commander mini hub, since installing 6 fan power pins on my motherboard was to messy.
Then i also have a corsair node pro that controles my 4 RGB strips from corsair.
But i dont understand how it affects the ram crc...all i can tell is that either G skill must recode ther ram or corsair must recode ther software.
So why do this corsair link program mess up the ram lights crc?
